Ram 2500 cargo capacity
   / Ram 2500 cargo capacity #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
My girlfriend has been dreaming about getting an RV. We crunched the weight numbers on a fifth-wheel, and I was surprised at the result. Here are the specs for my truck:
Code:
2005 Dodge Ram 2500 4x4 SLT Quad Cab Short Bed 5.9L HO Diesel Engine
GVWR:                            9000 lbs
GAWR (front):                    5200 lb
GAWR (rear):                     6010 lb
GCWR:                            20000 lbs
Curb Weight:                     6813 lbs (nominal) - 7220 lbs (weighed 3/8/2012)
Curb Weight (front axle):        4280 lbs
Curb Weight (rear axle):         2940 lbs
Max payload:                     2187 lbs (nominal) - 1780 lbs (weighed 3/8/2012)
Payload (front axle):            920 lbs
Payload (rear axle):             3070 lbs
Max towing:                      13050 lbs
The hypothetical trailer weighs 9000 lbs, with a 3000 lb cargo capacity for a total max weight of 12000 lbs. Since it's a 5th-wheel, 25% of that rests on the pin, which is 3000 lbs. This is 60 lbs over the rear axle's weight rating, which is close as makes no difference. The trailer's weight is 1050 lbs less than the truck's max tow capacity. And the combined weight of truck and trailer is 19,220, which leaves 780 lbs to spare. The only spec that doesn't measure up is the truck's GVWR. 9000 lbs GVWR - 7220 lbs curb weight = 1780 lbs cargo capacity, which is 1,220 lbs short of what would be needed to handle a fully loaded trailer, never mind the weight of additional passengers and cargo in the cab of the truck.
I'm kind of surprised that the cargo capacity of the truck doesn't seem to measure up to its tow capacity and/or its axle rating. One reason for this is that the truck has skid-plates on the undercarriage, which I think makes up most of the 400 lb difference between the nominal and the actual curb weight. Even if that was removed, it would still be short.
Are 3/4 ton trucks just not ideal for towing fifth-wheels? Are Dodge trucks particularly light in the cargo department? What's the deal?
   / Ram 2500 cargo capacity #2
Dodge trucks are known to be light in the cargo department even to this day.
Aaron Z
   / Ram 2500 cargo capacity #3
Yea, Dodges are known to be light on paper to legally handle cargo, ect. The new ones are no better.
To compare my 2004 F250 4x4 had 10,000# GVWR and weighed 7,500 with me and my wife in it at the Cat Scales. It left me a honest 2,500# for cargo/pin weight, ect. It replaced a 2003 2500 Dodge 4x4 for the same reasons.
The F250 has since been replaced with a F350 Single Rear Wheel 4x4. It has 11,500# GVWR and weighs 7,600# with me and the wife at the same Cat Scale so 3,900# is the payload.
Chris
   / Ram 2500 cargo capacity #4
I saw the same when shopping for half ton trucks. Dodge has a narrower margin between gross weight and curb weight, especially on the optioned out models. Perhaps they design for the regular cab base model and then let doors/options eat into the margin.
   / Ram 2500 cargo capacity #5
Don't forget to watch your tires also. Many 3/4 tons come with whimpy 245 tires that are not rated high enough.
Chris
   / Ram 2500 cargo capacity #6
I own an almost identical truck but its a 2004. Mine weighs about 100 pounds more but I also have a tool box in it with some stuff in it.
I will tell you this, but keep in mind it won't change what the sticker on the door says for legal reasons. The difference between a 3/4 ton and a 1 ton single rear wheel is the rear spring pack. The 1 ton single wheel has an over load leaf added to each side. For all practical purposes you could add that setup and be the same. The brakes, axles, frame, drive shafts, transmission and everything else is exactly the same. You could also add airbags and be good to go also.
When I read what people tow with these trucks on the Cummins forums you are well in what I would call the safe zone with that trailer but for legal reasons if you ever got in a serious accident someone might start looking at all the weights and technically you would not be legal.
That's the catch right there. I would be better off, legally, to get a bumper pull that only puts 10-15% of its weight on the truck, even though in some respects, a bumper pull tows worse and is somewhat less safe.
That was the thought I had. I bet cargo would be fine if I had a long-bed standard-cab.
   / Ram 2500 cargo capacity #9
. . . Since it's a 5th-wheel, 25% of that rests on the pin, which is 3000 lbs. . .
Need to check your math.
Typically, 5vers have a pin weight of 15-20% of the gross trailer weight.
No offense, but I have heard different. RV'ers I have read seem to say that you should calculate based on worst-case 25%, with 20-25% being typical.
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
