Rake Rakes
   / Rakes #1
Charlie175
Virginia
Mahindra 2015 gear
So how well do they work?
I acquired a wooded lot that has a lot of old broken branches and weeds. I thought about getting a rake to round up all the loose stuff so that I can mow it easier.
Do I need one with wheels?
   / Rakes #2
Wheels make it much easier to just scrape the surface (which is what you would want to do for sticks and such). That way you can just float the 3pt hitch and the rake with wheels will just follow the ground contour behind the tractor.
I used my rake to clean up debris before seeding my lawn last year and it worked extremely well. I have the Woods LR72 rake with the gauge wheels. I replaced the factory gauge wheels with flat proof ones though as the factory wheels sucked.
These are the wheels I used -
Marathon Tires Flat-Free Wheel 9 x 3.50-4in., Smooth | Lawn Mower Style | Northern Tool + Equipment
   / Rakes #4
My York rake with wheels doesn't work well gathering up light to medium leaves over lawn. It's probably because I don't want to graze the lawn underneath.
However when the leaves stack four to six inches, I can drag the pile to my compost heap.
   / Rakes #5
I borrowed one to use. The wife saw what it would do and SHE said I needed to get one. I can't think of very many tools the wife asked me to get:eek:
Not only will these things clean up, I was really suprised at how well they smooth and level. It does a much better job of smoothing the drive way than my boxblade.
Yeah there that good.
   / Rakes #6
I just bought a Land Pride LR 3584 7 ft landscape rake and it works as well as I had hoped. The best feature of this rake is that it can be swung off to the side of the tractor to allow the road ditches to be cleared with the tractor wheels still on the road.
This is a HD model and be prepared to spend twice the $ as a TSC rake. The swing to the side feature is only available on the Land Pride rake and I had to have this feature for my intended uses.
I raked out mudholes in the forest road down to hard clay with ease. I have a HD scraper blade, but it often digs down too deeply making a mess of things. The rake simply does a great job without the gouging problem.
I raked the mile of forest roads and cleared the surface of all rocks, sticks, and leaves with an out and back pass. I know time will make this even better.
Yes, I love this rake. It's great for spreading and smoothing the bigger stones for the base of my driveway.
   / Rakes
I just stopped by TSC and they only had the Force rakes...I'll pass.
I went by the tractor dealer and they had a BEFCO 5' for $590. It pretty much looks like the King Cutter setup.
They had a RHINO 5' for $890 that was a little beefier.
   / Rakes #8
I bought a 84 inch king kutter with gauge wheels for $540 bucks nice rake,but I wanted something a little more heavy duty,I ended up buying a befco BLR-084(84inch) with gauge wheels,IMHO very heavy duty rake verses the king kutter BUT,the price was $948 for the befco,I believe you get what you pay for.I would look at befco,woods,or landpride for a heavy duty rake.coobie
   / Rakes #9
You get what you pay for. The heavier and sturdier the better. Jay
   / Rakes #10
I agree bigger, sturdier is better MOST OF THE TIME, but sometimes bigger is too big.
I built a lightweight rake for my garden tractor that works wonderfully for leaves, twigs, small branches, etc. The design could be upgraded for a larger tractor. In the "push" mode it will move a huge amount of surface material without particles slipping below. And it does not tear up the ground nearly as much a a big rake (although it still leaves tine tracks on a groomed lawn). It is a simple design, easy and reasonable to build.
Here's a link:
http://www.tractorbynet.com/forums/build-yourself/112451-good-landscape-rake-cheap.html
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52128)
Adams Load Out...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
John Deere Disk Chisel (A50515)
John Deere Disk...
