Radio in my new 3520??
   / Radio in my new 3520?? #1
badels
Casper, WY
JD 3520 w/Cab
Hey guys. I've had my new 3250 now for a couple weeks and I absolutely love it. One small problem though, my factory installed radio will not keep time. The clock will reset if I don't use the tractor every couple of hours, sometimes even shorter. All of the presets and other memory type items stay programmed though. Any ideas?? The dealer is looking into it, but I don't expect an answer real soon. The beginning of hay season has them pretty slammed right now.
Brad
   / Radio in my new 3520?? #2
never bothered to set my clock. But it uses the same consyant lead for memory as the prest radio stations. Does your radio remember the presets? Ill set the clock tomorrow and report back
   / Radio in my new 3520?? #3
Hiya,
Check your ground straps, especially the ignition switch and cab ground. One of the symptoms of a poor ground circuit is resetting the clock on the radio as the voltage falls while cranking because of the higher resistance in the circuit. The stations don't reset because they are in flash memory, the clock is live.
Tom
   / Radio in my new 3520?? #4
Hiya,
Tom
Good to know. I thought they were all live
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
Galvanized steel fence (A53424)
Galvanized steel...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
40'' root grapple (A53421)
40'' root grapple...
2012 C.GALLEGOS 130BBL (A53843)
2012 C.GALLEGOS...
