BP blaster. spray some on, wait half day, spray some more on, wait another half day, spray some more on wait a half day and go at it. it takes some time for BP blaster to work down into the threads, and deal with rust build up.
getting a torch into area to help expand things might work.
make sure you use a 6 sided box end wrench or socket wrench vs other. so you do not strip the head of the bolt off.
find a metal pipe that fits over socket wrench or box wrench, and use it as a cheater bar. to help get extra force to turn bolt. i have some socket wrenches were i cut the C end off of a wrench to make it easier to put a cheater bar on. better yet get a "breaker bar" vs regular socket wrench. breaker bars are much easier to get a cheater bar on them.
do you have a good size air compressor and tank and air impact wrench? and zap zap zap them off. air impact wrench normally require a good size air compressor to run them decently. as in both PSI and CFM of air.
remember impact wrench sockets are normally black / dark gray in color and normally more costly than regular sockets for a socket wrench. reason? impact wrench sockets normally are made out of a higher grade of metal or thicker metal, that can withstand the force put on them from an impact wrench.
BP blaster, and breaker bar would be 1st choice first.
then go to buying a good air compressor to run an air impact wrench. if you already have air compressor that can run impact wrench, i would buy impact wrench and try that first. with some BP blaster.
