Radiator Overflow Hose Incident
   / Radiator Overflow Hose Incident #1
DK_Farms
South Louisiana
JD 4610 E-hydro 4WD, JD 5525 4WD Cab, JD 4066R
As I mentioned in another post, I foolishly brought my 4610 in to the dealer for its first service interval. I remember telling the service manager explicitly " Everything is working, please see that it stays that way." Well, guess what. I brought the tractor home and hooked up the RFM to mow a neighbors new yard addition. When I was on the second to last round, about 2 hours of mowing time, I would get the occassional wiff of antifreeze. Although it was 97 degrees outside, the temp gauge was still low. When I got home, I opened the hood and noticed a few drops of antifreeze scattered around the hoses and top of the engine. The source was the radiator overflow hose. Somehow it had gotten on the backside of the fan and the turning blades had worn the hose down until it made a pinhole that seeped a little. I replaced the hose, made it a little longer, and loosely tied it back to the radiator mounting frame with a ty-wrap to keep that incident from happening again. Was the hose in that position before it went for service? I don't know for sure, bit since I already have a long list of screw-ups with my name on it, I'll use the "coincidence factor" and blame this one on the dealer. /forums/images/graemlins/wink.gif Next time you go under the hood, check that hose routing.
   / Radiator Overflow Hose Incident #2
Similar thing happened to me, with my 4300 (radiator overflow tube leading back to the overflow container).
The plastic tubing became brittle and full of holes and the antifreeze solution was leaking out those holes. As near as I could tell, it was just a poor quality plastic and I replaced it with another plastic tubing.
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
Unused Delta Crash...
