Radiator leaking.
   / Radiator leaking. #1
duckhunter27
Dannebrog , NE
Bobcat CT 335
Worked my bobcat ct335 for 16 hrs this last 3 day weekened and now i am leaking anti- freeze. It seems tobe coming from right side of the radiator got it home late last night and have not had time to look it over good. Was wondering if any one els has had trouble with a leak ? and if radiators are covered by warranty? I have 106 hrs on my tractor.
   / Radiator leaking. #2
I haven't heard of any problems but the radiator is part of the 2 year full coverage warranty. Wouldn't be covered under the 3rd year driveline.
   / Radiator leaking. #3
Hey Duckhunter
If I remember correctly when I had to fix my radiator shortly after I got it the drain was on the right. I have a shop manual in the barn and can get you the removal process tomorrow night if you need it. See my other thread:
http://www.tractorbynet.com/forums/kioti-owning-operating/149384-need-new-radiator.html
Good luck and next year leave a few more waterfowl go by you up there in Nebraska so us Kansas hunters take your leftovers!
Tornado
   / Radiator leaking.
Well i finaily got time to check my leak? What i found was that on the lower right side sitting in seat there is a plastic out let that goes to a water filter i think any how that is where i am leaking at looks like the bottom of the plastic port is cracked i haven't pulled rad. or anything yet as tractor is still needed dosent leak all the time or very much. I think when i get time i will pull rad. and try JB weld I don't think this is a warrenty problem my guess is a ceder limb hit it.
2021 JCB 3TS 8T SKID LOADER (A51242)
2021 JCB 3TS 8T...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2018 INTERNATIONAL...
