Mowing Radiator filter on JD2038R
   / Radiator filter on JD2038R #1
SI2305
I asked this question previously but I got no response so I am asking again here. I am about to take possession of a new 2038r and I noticed under the hood that there is no filter screen in front of the radiator. It does have the front grille of course, but my 2305 has an additional removable screen right in front of the radiator and it collects tons of dust and debris that would otherwise end up in the radiator when I bush hog. Is it normal for a tractor with a larger frame to not need the additional screen? I commonly mow 5-7 foot tall weeds that shower down seeds and chaffe. Certainly a smaller frame tractor is going to be more susceptible to that dust, but does the larger frame tractor rise above this dust? And if it does not rise above the dust then what prevents the radiator from clogging with dust when bush hogging?
I appreciate your input as I plan to keep this tractor for a very long time and I plan to take good care of it.
Thank you very much in advance,
SI2305
   / Radiator filter on JD2038R #2
Maybe somebody took it out and lost it, I would get one:)
Actually my dealer just called me about this 5 minutes ago and he said only the 1 series has this screen due to larger tractors having multiple radiators and no place to put one. Peter, I agree that an additional screen would be good and I am wondering if other owners have had cooling/clogging issues with their radiators or how one would rig up a screen to put in place.
SI2305
   / Radiator filter on JD2038R #4
Looks like a poor design to me , My kubota's have them:confused3:
Peter,
What Kubota do you have?
   / Radiator filter on JD2038R #6
Thanks for the input. I may try to rig up something myself
   / Radiator filter on JD2038R #8
On the JD770 I had the screen slide down from the top
   / Radiator filter on JD2038R #9
SI2305
Wow... that is a surprise. All the previous 2-series had screens in front of the radiator. They are very important if you use your tractor for mowing. If you have a temperature gauge you can see the engine temperature increasing as the screen gets clogged and stop and clean it before the engine over heats.
Not sure what the dealer means about multiple radiators. Most tractors have at a minimum a engine coolant radiator and a oil cooler.
Heck, my old 9N even had a screen.
Jgayman,
The 2038r has 3 radiators in a row, making it difficult to place a screen down right in front to stop debris. He said no jd tractors larger than the 1 series has this screen. He told me he looked all over his lot and didn't find the screen on the 2,3,4 or5 series.
SI2305
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
