California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 14,983
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
OEM spec for the radiator cap on (most?) Yanmars is 13 psi. 7 psi also works well.
I hope this is convincing:
YM240 Parts manual: Cap # 124450-44590.
Numerous sellers online: 124450-44590 = Deere CH18207 which is 13 psi.
These Deere and Yanmar numbers are listed to fit a broad variety of Yanmars and Yanmar-built Deeres.
I did a very unscientific test on our current batch of caps (made by Kent) and the best I could tell they are 13lb. I used a digital scale and compared to several original Yanmar caps that we had left over. I do know that we used 7lb caps for many years also and had zero problems. Both work just fine.
I guess it all comes down to how much over the boiling point you really want to run your tractor?
With a 50/50 mix of antifreeze and a 7psi cap- your coolant will not boil until about 240 degrees. With a 14lb cap & 50/50 mix you increase the boiling point to about 260. The temperature warning lights should all come on at under 220 so both are well over that number.
