Rabbit/Turtle switch stuck
   / Rabbit/Turtle switch stuck #1
gpertuit
Southwest Florida
NH TC40D
While pulling up small stumps with my TC40D I notice my rabbit/turtle indicator was stuck on rabbit. It will toggle to turtle (either from the joystick or the panel switch) and the tranny will kick down to low, but when you release the switch it goes back to rabbit. Has anyone encounter this before? Thanks.
George
   / Rabbit/Turtle switch stuck #2
There have been several reports of the same or similar problems with the resolution being cleaning dirt out of the fender switch and having an electrical connector come loose under the left-side operator's platform. If you do a search of this forum for the word "turtle" or "rabbit" you will get lots of hits and be able to see the problem discussed in detail.
I disconnected the joystick switch and it worked correctly. A closer inspection revealed the rabbit button on the joystick was stuck.
Thanks for the reply Jim.
John Deere LA110 (A50121)
John Deere LA110...
43006 (A51691)
43006 (A51691)
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
1271 (A50490)
1271 (A50490)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
