Rabbit and Turtle problem
   / Rabbit and Turtle problem #1
Gaffrig23
Lewisburg, wv
New Holland TC45D
Hope someone can help. My TC45 does not change to low range with the dash turtle/rabbit switch, it is stuck in high range. I took the switch apart and checked for continuity and it is working properly. I do not know how to check the relays and also, I do not know which relays are for the hi/lo range as the parts diagram is not available from the internet parts suppliers I have been looking at. I checked for voltage at the two wires leading to the solenoid and only one has power, the other wire does not have power upon switching the hi/lo switch. Don't know what this means. I have ordered 2 relays but won't get them in the mail for a few days. In the meantime, I have trucks coming with fill dirt to spread, so here is the question : is there a way to get the solenoid to low range temporarily until I can get to the bottom of the problem? Any help will be greatly appreciated!
   / Rabbit and Turtle problem #2
Welcome to TBN. :welcome: Sadly our resident expert on the TC series Jinman passed away not too long ago. Here is one of his posts on how the system operates. You can also use the search function at the top. I used the key words "rabbit turtle" and confined the search to the NH Owning/Operating forum.
Hope this helps and let us know how it comes out.
http://www.tractorbynet.com/forums/...t-aesops-version.html?highlight=rabbit+turtle
   / Rabbit and Turtle problem #3
Not only was Jim an expert on these NH systems, but he was a real Prince of a guy, always willing to help a person out. He will be missed.
   / Rabbit and Turtle problem #4
The solenoid that drives the turtle rabbit feature is an energize to rabbit device. If the rabbit light is on, its electrical. If it isn't, the solenoid may be broke.
If you want to operate in turtle, just disconnect the wires to the solenoid.
I do miss Jim.
7041 (A39855)
7041 (A39855)
2012 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45046)
2012 ADVANCE...
Pallet of Load Bars (A39855)
Pallet of Load...
2011 Ford F-350 Knapheide Enclosed Service Truck (A42742)
2011 Ford F-350...
NEW TERAN TOP ROLLER GROUP EXCAVATOR ATTACHMENT for CAT 320 - (CR5592). (A40020)
NEW TERAN TOP...
20' Semi Dump Trailer (A44500)
20' Semi Dump...
