R4010 Shuttle Shift Getting Harder and Harder To Move
   / R4010 Shuttle Shift Getting Harder and Harder To Move #1
Short Game
Veteran Member
Sunny SW Washington
LS R4010 & Cub Cadet 7300
Over the past two or three years I have noticed that the shuttle shift lever has been getting tight and harder to move. It was first noticed in cold weather before the machine got good and warmed up. Once everything got some temperature in it, it was fine. Now, much stiffer than it used to be, and really tight when cold. This year, it doesn't get much better when it's warmed up, but it is a little better. Anyone familiar with anything like this on the 40+HP shuttle shift units, 2010 and newer?
Thanks.
Well, I may have it sorted out. I took the plastic cover panels off both sides, and the panel below the steering wheel, to expose things as best I could. All that could be seen from there was where the shuttle shift rod went down and out of sight through a rubber grommet. I blew all the dust and dirt away as best I could, after sliding the grommet up the shaft. Then I just sprayed some WD-40 down the shaft, with the hopes the issue has just been a dry oil seal. I worked the shift for a while and it seemed to ease up just a little.
I hated to think it was at the forward/reverse selector rail inside where the resistance was coming from. I just found a diagram in the parts manual and the only seal on that shaft is an O-ring on the forward/reverse shifter rod where it goes through a boss into the case. I guess it could have just been a dry O-ring. I suppose there isn't any reason the trans oil should reach it from below. It's way up high in the front corner of the transmission cases, and if it's not in the plane of rotation of any gear, it could just drain down and never get splashed much in light use.
After the shifter shaft sat with the tractor in the sun while I was in for lunch, it was moving easier. Now, what I felt was not very smooth operation, if it was at least easier. I am thinking that the spring ball and indexing notches on the rail could be dry there inside the case, from not much use, and sitting for most of the winter. There is no way to see that oil gets to that except maybe just some harder use and getting the trans oil good and warm and spinning that tranny up in high range to splatter some oil around. What do you think?
After sitting overnight, today it feels like it did when it was new. So, if anyone else runs into this issue, the good news is, a little WD-40 is way better than having to break the tractor in half. It is nice to have that thought undone.
Happy tractoring, all.
2019 KENWORTH T800 DAYCAB (A45046)
2019 KENWORTH T800...
2011 GMC Sierra Reading Service Truck (A44571)
2011 GMC Sierra...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A44789)
2010 Gleaner 9250...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2023 BAUMALIGHT MS1160 MULCHING HEAD (A43004)
2023 BAUMALIGHT...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A45046)
2019 ALLMAND BROS...
