Tires R4-Turf debate is over for me!
   / R4-Turf debate is over for me! #1
TheFlatlander
Howell, MI
Kubota BX2660, Kubota RTV400ci
BX2660 R4-Turf debate is over for me!
I have had a couple of BX tractors ending with my current BX2660. This time I purchased 2 sets of tires and had both filled rears with rim guard. Previously I had Turf tires and although I had liked them for my use and soil conditions-grass cutting on soft sandy soil and snow plowing in the winter I wanted to try out the harder sidewalls and more aggressive looks of the R4's.
Summary. Both sets of tires are very good for intended purpose. I found the ride of the R4 to be much rougher, but the firm sidewalls performed better when using the loader and hauling heavy on the three point. I regret that with the soil conditions that I have here that they are a little rough on the grass. I really like the ride of the turfs and how they are easier on the terrain. I really haven't used the R4's very much. Just for a couple of hours in the post lawn season when I wanted to do some more aggressive loader work and chipper work. Didn't get to use the R4's in the snow yet, and most likely will not, as I just came across an un-intended additional difference. The R4's are about 3/4" taller in ride height and cause a loud clanging noise when I try to park my tractor in the garage under the hoist. What a surprise! Glad I was moving slow.
Just got done putting on the Turfs back on for the last time. Man, are filled rear tires heavy and a pain to change. Turfs win for me. R4's are going on Craig's list this weekend.
Re: BX2660 R4-Turf debate is over for me!
Just an FYI addition, Kind of got caught up in the earlier discussion but tires and rims are like new. The front rims are the late model large diameter rims with low profile tires and will fit all BX's. If somebody local is interested PM me. The rears are filled and I am sure that shipping would be undesirable.
   / R4-Turf debate is over for me! #3
The R4's on my BX25 have worked out good so far, although we don't do any farming/construction.
   / R4-Turf debate is over for me! #4
I have owned 5 different tractors....1 Kubota and 4 JD's. I had turfs on the Kubota.......I liked them cause I basically used it for mowing only. R-4's on all the JD's. R-4's are better IMO for 3 point and loader work. My father-in-law is on his second BX25 with loader and backhoe. He has had turfs on both. Sometimes he wishes that he had R-4 tires but has been satisifed with the performance of the turfs......I guess it's a matter of preference and whatever works for you and your property.
   / R4-Turf debate is over for me! #5
I've got the R-4's on my BX 2660. Really happy with them. I can't believe how they and 4 wheel drive has gotten me out of every 2 wheel drive poor traction situation. Knock. Knock. Never been stuck where external help was needed. And not harsh on turf as long as the ground isn't wet.
   / R4-Turf debate is over for me! #6
Agree that it depends on the tractor and your uses. We have all three types and they work well for their intended purposes. We have more Industrial tires than anything though.
   / R4-Turf debate is over for me! #7
I would think that with a 2WD tractor the R4s would be needed unless all you were doing was mowing. Whereas with a 4WD the traction is large enough even with turfs to do most things short of farming.
Just a though with no actual experience except with 4WD, R4 and a tiller.
Am I wrong??
   / R4-Turf debate is over for me! #8
Am I wrong??
I don't think so, many TBN members use turf for everything they do including loader work and are happy with them.
My FIL bought a new MF 2 WD 375 with turfs. After a short time, he returned it for a 4WD with turfs on the back and ags on the front.
We use what works well for us and I am not willing to spend the money to do any experimenting with different tire combinations, so I can't definitively say how something else will perform.
   / R4-Turf debate is over for me! #9
Am I wrong??
Not wrong, but some terrain is different. If the ground is hard as concrete then the larger lugs on R1 (Ag tread) or R4 (industrial tread) won't sink in for that extra traction. Then all any type of lug will do it to reduce the amount of rubber on the ground and that reduces traction.
Our ground is rocky dirt with little grass and so we tend to run turfs for traction even on larger tractors. But we recently tried a set of R4s. They are a nice compromise between summer and winter traction. One difference that surprised me is how much stiffer the sidewall is on the R4. Frankly the sidewall is so different that I think that ends up making a lot more of a difference than the tread pattern.
rScotty
   / R4-Turf debate is over for me! #10
There is also the weight carrying capacity to consider. I'm in a bit of shock over the stock turf tires offered on my 4200. Add a loader, a backhoe, some RimGuard, and a full bucket and the stock turf tires are at the maximum weight carrying capacity with no margin for error. In fact, the front tires are overloaded with a full bucket when you consider the weight coming off the back and onto the front but I try to ignore that inconvenient little fact in my calculations. Needless to say, I've upgraded my front tires to heavier duty models and will do the rears in the next year or two as well.
Ag tires are even worse in this regard. Based on the specs, ag tires are strictly for 3pt work on my model of tractor.
Which is to say.... I MUCH prefer turf tires but I'd sure love to have someone make some extra strong ones.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2021 Liebherr L556 (A52128)
2021 Liebherr L556...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
UNUSED FUTURE SKID STEER HYD BREAKER (A51244)
UNUSED FUTURE SKID...
2008 Ford F-250 (A52128)
2008 Ford F-250...
