R4 Tires in snow
   / R4 Tires in snow #1
haveissues
New York
Kubota b2620
So I have to say the R4 tires on my kubota b2620 worked way better than I expected. I have a very steep driveway and had no issue getting up and moving around. A couple of times my front wheel went off the side of the driveway while piling up snow. After locking the diff I was able to back out uphill with no issue. I thought I would need chains but I don't think I will bother now. :cool2:
   / R4 Tires in snow
I'm cheap so I used windshield washer fluid but I could put 10 more gallons or so in each tire still.
   / R4 Tires in snow #4
I run R4's w/no chains but loaded rear tires,you might see change in traction when snow not dry.
   / R4 Tires in snow #5
I agree, I had R4's on my Kioti CK25 and in slushy stuff, it would slide all over the place on the hills. Chains fixed that right up. My :2cents:
   / R4 Tires in snow #6
My tractor with R-4's and loaded rear tires is near useless without chains when plowing with a 9' front blade.
   / R4 Tires in snow #7
I'll second that. I have v-bar 2 link chains on my front tires of the L3400 and I was fighting to keep my loaded rears behind me when I was pushing across the slope on some clean up passes. I was pushing an 8' meyers truck plow mounted to a homemade subframe.
   / R4 Tires in snow #8
i'm with you so far. have the same setup and not even a bit of slippage. of course i have it in 4 wheel drive, but again, no problems.
   / R4 Tires in snow #9
Ive had good luck with R-4s and Duo grip tire chains.
   / R4 Tires in snow #10
I also have R4s with steep gravel driveway, they work okay in snow but had to get chains for ice. Chains make a BIG difference.
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2000 FREIGHTLINER CC CONVENTIONAL (A52472)
2000 FREIGHTLINER...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
