Tires R4 tire rims for 4300
   / R4 tire rims for 4300 #1
pat32rf
Veteran Member
Bancroft, Ontario
JD4300
I was just wondering if they make adjustable rims that fit my R4 tires. Would sure like to move them out another coupla inches especially when running chains with the hoe on.....
   / R4 tire rims for 4300 #3
I have a JD 4300 and I wanted to do the same thing, Unfortunately, The rim diameters for the R4s are different than the Adjustable rims. Adjustable rims are made for R1 tires. You can reverse your rims and gain a couple inches. Move the right wheel to the left side and vis-versa. The valve stems will be on the inside of the wheel and the lugs will be going in the forward direction.
I reversed my R4 rims and it didn't look like much but I could feel the difference on the hillsides.
Good Luck, Marshall
   / R4 tire rims for 4300 #4
I had my wheels reveresed with normal R3 turfs, but when I for the Sprecial turfs, i could not put the rears on in reverse as the axle was too close tro the valve stems for me,.
I have been running them reversed but it only makes about 2" difference, if that....With chains and the hoe there isn't much clearance.
   / R4 tire rims for 4300 #6
Might wanna try hub extenders (wheel/axle spacers)?
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2013 Chevrolet Sonic Sedan (A50324)
2013 Chevrolet...
2006 Ford F-550 4x4 Flatbed Truck (A50323)
2006 Ford F-550...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
