R4 and turf tires together?
   / R4 and turf tires together? #1
TheGreyRider
Bronze Member
Central Pennsylvania
Kubota 2920
Does anyone out there run R4 rear tires and turf front tires on a 4x4 tractor?
I have a 2620 and would like to switch from R4 front tires to turf, but leave the rear R4's on. Would this cause any issues with the 4x4?
   / R4 and turf tires together? #2
Note sure of the benefit, but you should make sure that the sizes (especially outer diameter) are properly in sync with whatever the owner's manual specs. If your goal is not tearing up turf when you turn, the benefit will be marginal (especially in 4WD). The turfs are gentler on the lawn for overall use, but if you crank a hard turn in 4WD, they will tear a rut like any other tire.
   / R4 and turf tires together? #3
I currently swapped my rear R4's to turfs for mowing. I still have the front R4s on (long story)
I measured the the Rolling circumference of both my rear tires, actually mounted on the tractor, and they were within .5" of each other.
103" for my loaded R4s, 103.5" for unloaded turfs. They are within acceptable tolerance to each other imo.
I have used my 4x4 with this setup in the dirt with no problem. I too want to swap the front tires to the turfs but haven't got around to it yet.
Do you have your front turfs mounted on wheels already? The wheel specs are the same for the R4 and R3 wheel, but the construction is a bit different. The industrials have a guard over the valve stem, and its located close to the edge while the turfs are more towards the center of the wheel. Kubota does have different part#'s for the wheels.
The parts guys thought it should be fine, but I haven't tried it yet, and may just take it somewhere to get mounted, but don't want to be out $ if it doesn't work.
Currently have unmounted front turf tires sitting in the garage
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
