hutchman
Veteran Member
- Joined
- Mar 11, 2014
- Messages
- 1,447
- Location
- Central Virginia
- Tractor
- LS R3039, Deere SST16, Ariens APEX 60", Polaris Ranger 900 XP EPS
Hi,
Warning ... tractor noob alert.
In looking at my new-to-me R3039 today and reading the manual ... I'm a little confused about the draft control. Where the top link connects there is this little Y looking metal part that can swing up from the left. The brace for the top link looks like it also has room to press in on a lever I assume is the sensor the book mentions but gives a terrible description of.
So if my mechanical aptitude is right (or lack thereof), if this Y part is flipped up it looks like it prevents the top link brace from being pushed in which disables draft control feature???
I'm guessing the sensor works by a ground engaging implement pushing the top plate in (toward the tractor) as the load on the implement increases.
Am I in the weeds on my understanding? Just trying to figure this thing out.
Also, the manual talks about selecting "proper hole" for the top link but really doesn't go into detail about how to determine what the proper hole is. In looking at it, it looks like the top hole would have more leverage and be the most sensitive to draft control and the holes further down would be less sensitive ... is there some fine art to deciding which hole to use to connect the top link?
