r JD/ Yanmar injection pump question
/ r JD/ Yanmar injection pump question #1
JoeJChin
Archbald Pa
JD 750
Anybody out there familiar with the following type injection pump ?
link to picture
http://www.jhdiesel.com/Mvc-017s.jpg
It's a Yanmar pump off a JD 750 compact tractor .
I was having trouble getting the tractor started , and ended up pulling the pump off of it .
I don't think the pump is working properly .
After all the normal bleeding purging etc trying to get the tractor started again ( 20 minutes after shutting it off )
I pulled the access cover off the side of the gear case , and it doesn't look like the rack is moving in the pump when i move the throttle lever back and forth .
If you look at the right hand picture , what i have seen called the rack , is the rod , with the pin sticking out of it .
The pin is what sets into the yoke of the throttle arm .
I pulled the pump out , and i can move the rod , but it moves very hard.
Kind of takes two thumbs on it to make it move .
The only reference i have seen , is that it "should move freely" .
I was wondering if anyone here has had one out and can tell me how "freely " it is supposed to move , and if there is any reason
it would get so hard to move while i was running it .
thanks
Joe
/ r JD/ Yanmar injection pump question #2
Unable to give any reason for failure of pump But I would take it to a diesel injector shop to be checked.
since already have it removed. mark any points to be remembered and let some one experanced give a suggestioin.
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2020 International LT625 48" Sleeper (A62613)
2020 International...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
