quits running
   / quits running #1
rjslapshot
John Deere 108
:mad::mad::mad:I just bought a used jd 108 lawn tractor.Just tuned it up, and also put on a new fuel pump. Here is the problem , the tractor runs great for a half hr. then it wants to stall. LIKE ITS NOT GETTING FUEL Its a 18.5 kol. motor. I called a jd dealer he told me to check the gas cap vent,that seemed fine. Any ideas on what to look for.
   / quits running #2
How did he tell you to check the gas cap? Did you feel a release of pressure when you unscrewed the cap? Did you check the cap immediately after the mower shut off after 30 min of running or did you check it with the engine cold and not previously running? Explain the proces you used.
   / quits running
I checked it with the motor cold. He told me to stick a sharp object into the vent hole, and make sure you can blow air through it.
   / quits running #4
After you did that, did you mow with it for over the 30 min time limit to see if anything changed? If not, try mowing or running the motor for the 30 min to see if it still shuts off. (If) and when it shuts off, loosen the gas cap and listen for a vacuum release. If you hear one a new cap is in order, if the cap is plugged (and it still could be after you blowing into it) the fuel pump draws fuel from the tank to the carb until there is a vacuum build up in the tank above the fuel level which the fuel pump can not overcome to draw fuel to the carb. That is when the mower actually does run out of gas even though the gas tank may have 3 gallons of gas in it. A new cap runs about $10. Next time the mower shuts off remove the cap and try to re-start the mower. It will take some cranking as the fuel line and filter will need to re-fill with gas if the cap is the problem. If it doesn't run after this procedure then, like you said, the cap is not the problem and more testing is in order.
A bad cap may be the reason the mower needed a new fuel pump. The vacuum eventually breaks the fuel pump diaphram which causes a gas leak at the pump.
   / quits running #5
If I thought that the cap was the problem, I'd drill a 1/8" hole in it and see if it fixed the problem. If not, I'd fill it in and move on to something else.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
2015 Ford F-250 Service Truck (A53422)
2015 Ford F-250...
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
Krause Dominator 4850-18ft (A55301)
Krause Dominator...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
