Quieting the RTV
   / Quieting the RTV #1
rleonard
S. Central Illinois
Case 580SK, RTV 900, Toro GM322, + others
Going from the Mule to the RTV, the RTV is quite a bit noisier. Granted there is a lot more machinery back there but I'd like the group to kick around a couple of ideas.
I am thinking of placing "leaded foam" a material made for sound damping under the bed, and perhaps a fabric (carpet?) on the underside of the roof and onto some of the interior panels. Here is a link to a company that makes such material. web page
Any other ideas?
Thanks,
Bob
   / Quieting the RTV #2
Bob,
I too have thought about putting in some sort of sound deadening material but never really got around to it.
Not sure about the mule but when I compared the noise of the RTV to that of the Ranger, I found the RTV to be the quieter of the 2. When you increase RPM's on the RTV, it doesn't seem to get any louder, it just changes tone. I can still talk to my kids when driving at any speed. The Ranger got so loud at higher RPM's that 2 adults would need to yell to hear each other.
Why put it in the roof and other interior panels? I was thinking of mounting to the bottom of the cargo box and some under the seat (carefully so I don't block the radiator and other components under the seat.
If you try that stuff, let us know how it goes. It looks a bit pricey as it'll take $130 to do the area under the box but if it works, I might be game.
Brian
   / Quieting the RTV
I ordered the following materials from McMaster Carr today. I'll document and advise on results.
4 2
Ft. 53925T75
Polyurethane Sound Absorbing Sheet W/Barrier Plain Surface,.25"/1" Foam Thk, 1.30" Total Thk, 54" W
$32.36 $64.72 today
5 5
Ft. 5692T53
Flat Sound Absorbing Foam Adhesive Back, Reinforced Foil-Faced, 1" Thk, 54" W
$11.15 $55.75 today
Bob
   / Quieting the RTV
I posted pictures of the sound insulation install at this link to my album.
http://photos.yahoo.com/pilot_bob
THe insulation helps, but more work is needed. The engine is in an open area. Lots of noise bounces off of the ground and out.
I think that the fan is a source of a lot of the noise. Not sure what good it does and I am thinking about removing it to see the difference. Comments?
Bob
   / Quieting the RTV #6
Bob, I looked at the pics. Nicely done.
</font><font color="blue" class="small">( I think that the fan is a source of a lot of the noise. Not sure what good it does and I am thinking about removing it to see the difference.)</font>
Personally, I wouldn't think that the fan is a major source of noise on a diesel engine. As cool as the RTV tends to run, it does "seem" like that fan may not be required. The 2nd fan could/would kick on when it gets hot. I guess I wouldn't do it since they put it there for a reason. It probably wouldn't hurt to pull if off to do a sound test to see how much of the noise is from the fan.
Brian
7022 (A50322)
7022 (A50322)
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
TMA (A49461)
TMA (A49461)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
400 gal Fuel Barrel on Skid (A50515)
400 gal Fuel...
2012 Ford Expedition SUV (A50324)
2012 Ford...
