Front-End Loader Quickie Loaders (FEL)'s
   / Quickie Loaders (FEL)'s #1
barrylndn
Does anyone have, or has anyone used, a quickie loader? If so, how do they compare with original equipment, ie john deere tractor - john deere loader, kubota loader, etc? Also, how do they compare with other aftermarket loaders like Westendorf?
   / Quickie Loaders (FEL)'s #2
I have one, but I don't have anything to compare it to, it's my first loader on my first tractor. I have 200 hrs on tractor, and there hasn't been anything the loader hasn't been able to handle.
   / Quickie Loaders (FEL)'s #3
Quicke now manufactures the loaders for the CNH Utility and Ag tractors.
I've heard that about CNH, and also that their loaders are OEM for Kubota in Canada (according to Quickie), but I don't know anything about them as far as usability, quality, etc. I'm really most interested (should have been more specific) in the different in boom/bucket/3rd valve controls. their joystick vs the smaller controller they offer. Info?
   / Quickie Loaders (FEL)'s #5
What I do know is that A LOT of utility tractors used by farmers in my area have Quickie loaders.
   / Quickie Loaders (FEL)'s #6
You will get a better loader if you buy the aftermarket product. The OEM's make a lot of different equipment, but for the most part a loader is an accessory for them and not a main product line item. The aftermarket manufacturers are specialists in the business, we spend more hours on R&D, new innovations and fit of the loader. Here's another way to put it...
If you were going to put in an awesome surround sound theater system in your home, would you go to the contractor that built your house or would you go to an Audio/Video store that specializes in that type of equipment?
Just do your research, consider fit, strength, quick on and off, maintenance, resale valve, versatitlity and especially know what you want to achieve with your loader; then compare it at Front-End Loaders by Westendorf: loader for tractor, shade canopy, wagons, manure & landscaping equipment.
   / Quickie Loaders (FEL)'s #7
I guess you are right with the specialty part as well as the fit. IT is often tough to figure out how to get one model of loader to work for as many models and makes of tractors you do! Some even offer more lifting ability then even the tractor manufacturers loaders do, I wonder if that might not be bad in the long run for the front end?
I've never heard of a stereo system being to heavy for a house, I have heard them to loud, but I have seen tractors split in half from to much weight in the wrong place.
   / Quickie Loaders (FEL)'s #8
I'm no expert but neither a loader nor a backhoe seem so integrated into the main design of a tractor that one ought to be concerned about an aftermarket product for any reason.
Tractors overall are pretty simple machines and I don't think that integrating a backhoe from here or a loader from there has any real downside. JMHO.
   / Quickie Loaders (FEL)'s #9
A lot of the dairy farms around here go with Quickie loaders on their John Deeres, Valtras, Case-IH and New Holland tractors. My Valtra dealer who sells Quickie loaders usually has a new tractor from another brand in their lot waiting on a Quickie loader. They have always had a great reputation as a loader company as has Westendorf. I think you will be happy with either.
   / Quickie Loaders (FEL)'s #10
This is definately something any aftermarket manufacturer will consider before recommending a loader on a tractor. In our case, we consider front end capacities and would not recommend a loader that would be too large or one that could overpower the tractor. We also check the strength of the frame and include a rear axle kit to strengthen (tie front and rear axles together) if necessary.
My best recommendation is to always ask to "see" a photo of the aftermarket loader installed on your specific tractor. You'll be able to tell if the loader is too big for the tractor.
2007 JARRAFF 540 TREE TRIMMER (A51242)
2007 JARRAFF 540...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2015 CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
Case 586E Rough-Terrain Forklift (A52128)
Case 586E...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
