Quick Tach quick attach plate
   / Quick Tach quick attach plate #1
pekabu
Platinum Member
NH
TC24D
Saw this on eBay. eBay quick Attach plate
I am looking to fix something up to remove my bucket and put forks on. Don't want to go the clamp on route. Not really looking to use skidsteer attachments (TC24).
I have seen some of the discussions on the kubota version and I think I have seen a JD version but I didn't find any discusion on this setup in my search.
   / Quick Tach quick attach plate #2
I haven't used on of these before and can't quite picture how this would work?
Can you tell me more about it? I have some "L" shaped forks and would like some ideas...
-JC
   / Quick Tach quick attach plate #3
I bought mine brand new from the Bobcat dealer for $89. It didn't have anything cut off to save weight.
The plate has angled metal brackets on top for the quichtach "skidsteer" arms to slide into, and holes on the bottom for the locking pins. You would weld your attachment onto this frame.
   / Quick Tach quick attach plate #4
Dave,
When I bought my current tractor I also bought a quick-attach for the FEL (MF). This system is designed to use the regular pin type bucket or forks, etc. The lower pin is removed from the attachment. When you change attachments you have to pull the two lower pins. It only takes a couple of minutes to go from bucket to forks. I've read discussions indicating that other manufacturers offer the same setup, so I would think NH has something similar. I think mine was about $175. With this type system you don't need to add plates, etc. to your attachments for them to work. If they are pin type and will match your loader now they'll work with the quick-attach designed for your loader.
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
28013 (A50322)
28013 (A50322)
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
