quick release bucket
   / quick release bucket #1
bcoving
olive branch ms
r4047
The pins are stuck on my quick detach for the bucket. Does anyone have a tip to get them loose. Trying to put my grapple back on. Never had this problem before.
   / quick release bucket #2
See if you can see which side the pin is rubbing in the slots and push the bucket up against something to relieve to pressure.
   / quick release bucket #3
I've had to tap the side of the pin before with a hammer.
   / quick release bucket #4
It happens with my 3037 from time to time. I just keep a box wrench in the cab for when it gets finicky. Loosen the bolt and the pin slides right in.
Then, you figure out that if you pull the handle too far in opening, THAT'S when it jams. Just don't go ripping at the handles. It'll work just fine.
I think I caught my left on in the up position, once picking up my pallet forks and bent it pretty severely. I just pounded it back straight.
Little did I know that it would hamper the closure of the pin into the various attachments.
Bought another handle. Just haven't installed it yet.
It's on the list, though.:laughing:
For about a year now. I think?
I'll get around to it. It just hasn't ticked me off enough yet.
know that it sould hamper the action of the piston
Thanks guys. I sprayed it with wd40 and worked the handle back and forth. It came loose.
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
TRAILER AXLE (A51244)
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51243)
2001 HAULMARK...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
INSPECTION (A51572)
INSPECTION (A51572)
