Quick Question
   / Quick Question #1
docmx
A while back I bought a used M4900. I've noticed it has a small piece of metal welded to what appears to be a lock nut on the base of the top hitch just below the grease fitting. The metal piece is the diameter of a pencil and about 3-4" long. I can't find anything about it in the operator's manual. What purpose does it serve? Just curious. Thanks.
   / Quick Question #2
If I'm not mistaken, I believe that is to put tension( tighten against adjusting sleeve) on the lock nut when you adjust the 3rd link length. Without it you would need a wrench and this alleviates that problem!
   / Quick Question
Hmmm...interesting. Thanks for the reply.
   / Quick Question #4
How about posting a pic.
2020 Gehl R220 Skid Steer (A50490)
2020 Gehl R220...
2012 Chevrolet Tahoe LS SUV (A48082)
2012 Chevrolet...
2017 Mercedes-Benz C300 Sedan (A48082)
2017 Mercedes-Benz...
NEMA HF78 50HP Vertical Hollow Shaft Electric Motor (A49346)
NEMA HF78 50HP...
2016 Ford F-550 4x4 12FT. Landscape Dump Truck (A48081)
2016 Ford F-550...
(2) Battery Powered Drills and Case (A48837)
(2) Battery...
