Quick question- Rhino oil check
   / Quick question- Rhino oil check #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
When I check the oil in my Rhino, do I screw the dipstick in or not?
THANKS!
   / Quick question- Rhino oil check #2
I don't know anything about the Rhino but anytime you check an oil dipstick for any application it should be fully inserted first.
Cheers,
Mike
Not necessarily. I had a Yamaha ATV and to check the oil you remove the dipstick, wipe, and insert to threads but do not screw in. I had a Kaw. ATV that you did have to screw in. With the low capacity of these engines, that little difference could be alot.
   / Quick question- Rhino oil check #5
The 2006 Rhino I owned did have a screw in dipstick. Some engines you check screwed in some you don't. The Rhino IIRC was not screwed in to check, but some engines you do screw it in to check.
The Yamaha site has free downloadable owner's manuals if you don't have one, rutwad.
Thanks guys. I found my owner's manual.
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
377669 (A51573)
377669 (A51573)
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
