Quick question regarding assembly of Prince stackable valve
   / Quick question regarding assembly of Prince stackable valve #1
93Mustang
Chester County, PA
JD ##@)
There are a number of o rings that I need to keep in their respective spots as I bolt the pieces together. Any suggestions on what I can use to keep them in place ? Anything else I should be aware of as I do this? Thank you - Dana
   / Quick question regarding assembly of Prince stackable valve #2
If you lay one end piece with the bolts up, then lay the o-rings in place and lay the next spool assembly/stack on it and continue until the end piece is installed and tighten the nuts. A little grease might help.
   / Quick question regarding assembly of Prince stackable valve #3
Vaseline and being careful will hold the orings in place for assby.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
ROLL OFF BOX (A53843)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
