Quick question in regards to a 224 and 284.
   / Quick question in regards to a 224 and 284. #1
Rusker
How similar is the front axles and internals on a 224 compared to a 284?
   / Quick question in regards to a 224 and 284. #2
If you're counting on them be universally interchangeable, don't. The 224 has been sold as tractors of two different physical sizes and weight. Some belong to the 184-204 size group, others belong to the 254-284 size group. Depends upon how it was ordered by the importer.
It can be done, but give very specific measurements to your parts source.
//greg//
   / Quick question in regards to a 224 and 284. #3
</font><font color="blue" class="small">( How similar is the front axles and internals on a 224 compared to a 284? )</font>
Hey Rusker,
That quick little question may turn out to be a long one. /forums/images/graemlins/shocked.gif
I have heard on these forums that they have the same chassis, but that the difference is the size of the engine in the 224, 254, and the 284. However I have also heard that the 204 is also being sold as a 224 by some, but with different decals. Heck I don't really know for sure, but If you are serious about which is which. Then the best way that I know of is to go to a dealer that has them, and sit the 200,224,254 & 284 side by side and then compare. Look at the engine plates and copy down the engine data and the rated KW @ the specified RPM.
I think JohnS might be a good source for this type of information, as he knows these Jinma tractors inside and out, rightside up and upside down, sitting straight up on the rear end and going straight down with rear end up. /forums/images/graemlins/smile.gif
Have a nice day,
Joe
   / Quick question in regards to a 224 and 284. #4
To the best of my knowledge the center section/differential are the same on the entire range of 200 series tractors 184-284, however there are longer axle housings and axles on the big 224, 254/284 than on the 184,204 and "small" 224. There is a difference in drive shaft length, but his probably has more to do with engine length than chassis difference. A visit to your parts book will show the different part numbers for the different variations.
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
Electric Concrete Mixer - (A51573)
Electric Concrete...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
