Quick Question for the LK3054 Owners..
   / Quick Question for the LK3054 Owners.. #1
Denis A LeBlanc
Kioti LK3054, JD 445, JD 455
Good Morning. I have the LK 3054 and after sitting for a week, I went to move the tractor and found that I was having an Issue putting the tractor into gear or high low range it it's already in gear. Tried to adjust the peddle travel, but ran out of travel.. The gears are not meshing, which tells me the clutch assembly isn't disengaged enough.. If I get it into gear, the tractor starts to creeps forward with the clutch peddle down like it's engage.. Opposite of what I think a worn out clutch would be, not grabbing at all, this situation appears like the clutch isn't retracting enough to be able to get it into gear without that terrible gear grind... All at idle RPM... Any help or direction would be appreciated.. Still learning and trying to find a shop repair manual for this.. Saw one on Southern Global parts.??? Thanks for the help.
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2021 Ford F-450 (A55973)
2021 Ford F-450...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
