Rotary Cutter Quick question about Bush hog
   / Quick question about Bush hog #1
lockman4288
Wiscasset,ME
3240 HST TLB cab
I am looking at purchasing a land pride 5ft bush hog I need to mow a pretty steep drainage stream dose a brush hog angle down at all when attached to the 3 pt or is there another attachment I should look at
   / Quick question about Bush hog #2
You can angle it a bit with your 3pt hitch attachments, but I think you may want to look at other attachments for a steep angle.
   / Quick question about Bush hog #5
You wont need to angle it, the tractor will be at the same slope as the bush hog which is level with the ground so in essence it is still level with the ground when you are on a slope.
As Roy says, if slope is very steep at all, I would back up and down it or if you can cross it, just drive across and turn and go back across. You may have to unhook the top link to allow the bush hog to "float " if the ditch bank is very steep or deep.
   / Quick question about Bush hog #6
Yep, and make sure your PTO drive shaft has adequate (but not too much) overlap
   / Quick question about Bush hog #7
I have some pond levies are just too steep to mow on the water side along the slope parallel to the water and I back down using the hydraulic top link to lower the back of the cutter to contour to the drop off.
   / Quick question about Bush hog #8
   / Quick question about Bush hog #9
I've been looking for something similar. This might interest you.
Another option might be the Orsi River Compact boom mower:
Orsi Group
That Orsi boom mounted sicklebar mower looks really neat. IIRC, another TBNer had posted info about the sicklebar mower. Apparently, it only requires about 15 PTO HP to operate. Again, IIRC, the price is about $6500.00.
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
