Quick! Kohler KT17....
   / Quick! Kohler KT17.... #1
Tractor Beam
Cast iron bore, or aluminum? Are they a decent engine? They are in the 317 which I'm lining one up to buy..........
   / Quick! Kohler KT17.... #2
There were two versions; one was splash lube, the other pressurized. Stay away from the splash-lube model. Pretty sure they're both cast iron and sleeved.
//greg//
Excellent! Any idea how to tell them apart?
Just found out that the pressurized Kohler is the series 2. I'm wondering if they were any good?
   / Quick! Kohler KT17.... #5
A well-kept 317 tractor with the series2 KT17 is a good combination. Before I knew the difference, I had the splash version. Hindsight taught me that it's no good for mowing anything but billiard tables. When mowing off-level, the uphill cylinder gets oil-starved. Ignorance cost me an engine.
Examine both front spindles closely though, they have a tendency to crack with age. If you see a crack - it may look just like a rusty hairline - you can count on replacing it after some future bump in the road. Also make sure there's no binding in the deck lift mechanism. It's getting harder find 317 deck parts these days. You want it to move up and down without noise or hesitation.
//greg//
Gosh, I'm beginning to really lean towards the 112. I found a fully restored one in my area for a bit much, but geeze is it cool!:cool:
   / Quick! Kohler KT17.... #8
You do realize don't you, that the 112 is a one cylinder? That's 663 pounds of machine plus 16 pounds of gasoline plus you - on a 12 hp Tecumseh one lunger that was made at least 40 years ago. Unless you get one of the last two model years ('73-'74) that is. They were Kohlers, but pretty sure still 12hp one cylinder.
//greg//
Actually 10 and this one is a 1970 but it's been restored. We're sort of all over the place, considering also the 400 and looking at a new Kubota diesel as well. The 112 would be a slow way to go for our large lawn, but we might get a 6 foot brush hog to help curb the grass a bit too. still mulling it all over.:confused2:
   / Quick! Kohler KT17.... #10
I've got a 317 with a kt17 series 2 in it. I put in the series 2 after my series 1 blew. The series 2 is a really strong reliable engine. I've used my 317 for mowing 3 acres, tilling a one acre garden and running a 49 snow thrower.
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
2011 JOHN DEERE 670G MOTORGRADER (A51406)
2011 JOHN DEERE...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
Utility Trailer (A52377)
Utility Trailer...
