Quick Hitch
   / Quick Hitch #1
gerard
Veteran Member
Syracuse NY
Kubota L2500DT w/FEL
Anyone have pros/cons, real life experieince with the quick hitch's? I like the idea of buying one unit ($200) that will work on all the 3 pt implements as opposed to the freedom hitch where you need to buy the tractor part and then an implement part for each piece. Just too expensive for my needs. Do I just have to make sure all my implement pins are spaced about the same so the quick hitch will fit? I can justify $200 but not the $1000 it would cost me to go with a freedom hitch system. (I tried to do a search w/o any luck 'cause I thought this had been visited before.)
   / Quick Hitch #2
I'm surprised you didn't find any hits in your search - maybe it was thrashed thoroughly in the previous incarnation of this board, but I do remember it being discussed a number of times.
The only types of quick hitches I personally know of are the SpeCo (or is it SpeeCo?) (also sold by Landpride under their name - at least they look identical), the Freedom Hitch, and the Delta Hitch.
I had a SpeCo hitch that I bought 7 or 8 years ago lying in the woods until I gave it away a few months ago. Some folks like them fine - their value to me is the going rate of scrap metal minus what it would cost me to transport it to the salvage yard. It would only work with 2 of the 5 implements I wanted to use it with, so it was far easier to do without it. I would suggest you look at one, measure the attachment points, and very carefully measure all of your implements. Especially take note of the fact that it has to have room to slide up vertically several inches to engage the pins. If it will work with your implements, you'll probably like it fine, of course, otherwise it's junk. Another thing you should think about is that there's a lot of slop with this hitch, so I wouldn't make any great plans to do any real fine grading or delicate operations with it.
The Delta Hitch is very similar to the Freedom Hitch, except that it costs more, so that puts it out of contention in my book.
That leaves the Freedom Hitch. It's more expensive than the SpeCo model, as you say. But if ever there were a case of getting what you pay for, I'd say the Freedom Hitch is it. Mine causes a sensation every place I go - any time there are folks around who have spent much time hooking up implements the hard way, they just stand and marvel over the ease of use. Frankly, I still feel pretty much that way every time I use it myself. Still, if you don't change implements often, or don't have the money, it's not worth it, is it? I wouldn't give mine up - I'll tell you that.
MarkC
   / Quick Hitch #3
MarkC,
Does anyone else besides yourself use the Freedom hitch? My wife would use the tractor more if the implements were easier to hookup. Right now she will use them - only if I do the hookup. The freedom hitch looks great but am a little leary of investing that much money without knowing how well it works.
Have a box, blade, finish mower, and rotary mower. Some days I switch between three of the four and it gets a little old. With the way the freedom hitch looks on the website I might just switch for the fun of it (or to show off to some knuckle bangin' friend /w3tcompact/icons/smile.gif).
DaveV
   / Quick Hitch #4
DaveV,
I'm by no means the only one here that uses the Freedom Hitch. JackinIL uses them and he's an even bigger critic of equipment than I am /w3tcompact/icons/wink.gif. I know there are others, but I can't remember who they are at the moment. (Muhammad, how about a way to search the bio pages?)
I really wish you could see them for yourself. That would clinch it for you. They're amazing - that's the only way to describe it. Two things to remember, though: You need to be able to set the front of an implement like a blade on something for it to work right. In other words, it needs to be supported and not rest directly on the ground. Secondly, you'll still need to hook up the PTO shaft the normal way, where necessary, of course.
If you have any other questions, I'm sure one of us will be happy to answer them.
MarkC
   / Quick Hitch #5
   / Quick Hitch #6
Thanks for that web sight Rch. I order some info from them this morning.
Mark is right about the Freedom Hitch. I wanted get one but I have too many things to spend money on right now. However, my neighbor who has chicken houses saw the video and bought the Freedom Hitch and 3 hookups. He loves it!
   / Quick Hitch #8
I had a really hard time hooking up implements (and my wife quit trying) with my Massey.
With my Kubota M6800, it has extendable lower links, adjustable pins in the stabilizers, good emergency brake, and I have a top hydraulic link. Yes, a quick hitch could be a little faster, but it is hardly any effort to hook them up now. The PTO shaft takes longer than the 3 point to hook up. I think Kubota has done a nice job on this in their new tractor designs. I am sure if I did landscaping or for hire work, I would feel that the cost of a quick hitch had a quick return on investment.
   / Quick Hitch #9
Just got some info on the Bubco quick hitch. They have a video tape they're sending. I got some price quotes and they seem really high. Think you need a hydrolic top link as well. Will take more time to study tonight.
   / Quick Hitch #10
A Bubco rep just called me and is sending a video and other info. He has already received several requests for info due to their web site being put on this forum. I invited him to join the site.
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A51222)
2019 FREIGHTLINER...
CATERPILLAR 926M WHEEL LOADER (A51242)
CATERPILLAR 926M...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
