Quick hitch 3pt
   / Quick hitch 3pt #1
drg1
Missouri
1532 hydro
Anyone out here using a quick attatch on their 3pt on a 1500 series tractor
   / Quick hitch 3pt #2
What type of quick attach are you looking at? I bought a Speeco quick hitch when I had my Kubota BX23 (subcompact) - and I kept it when I went to a Kubota B3200. It definitely makes swapping implements easier on the 3pt - and for me it made hooking up implements a simple back and pick up operation - vs - the 1/2 hour of cursing and manhandling it was taking to get some things attached before.
Definitely a good upgrade.
   / Quick hitch 3pt #3
I've got a speeco also on my MF 1643 and don't think I could live without it!
   / Quick hitch 3pt #4
I use a speeco on my B7510. Made life so much easier in the summer time since I don't have to sweat and curse for half an hour to hook up a 3 point implement. On the B3200 I use something similar to Pat's quick hitch. The ones that fit on the end of the lift arms. I cut a 2" diameter pvc pipe the right length to hold the arms apart when backing up to an implement. I have used bungy cords strategically place to do the same thing. I find that attaching a pto driveline is easier with the end of arm hook type quick attach. That is just my preference. Either way attaching an implement is a one man 10 minute job. Great upgrade.
   / Quick hitch 3pt #5
If you are thinking about a quick hitch look at the JD imatch. IMO it is the nicest qh out there. You have better visibility with it than a speeco style QH.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2001 GULF STREAM CONQUEST (A51247)
2001 GULF STREAM...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
