3-Point Hitch Quick drop valve
   / Quick drop valve #1
awellc
Seattle, WA
Ford 4610
Hey guys I need help. I"ve got a 1982 Ford 4610 that was given to me. It came with a FEL that does't look like it came with the tractor. It is off the tractor now as I had to rebuild the engine. The engine is done now and I am still in the process of reconditioning the poor old girl. I took it for a test drive the other day and it ran great. I started testing and learning what does what and cannot get the TPH to work at all. I can move the arms up and down by hand. After reading some threads on TBN I think I may need to connect the hoses together that go to the loader. They don't fit into each other so I thought I might be able to pick a brain or two before I start buying fittings to connect the hoses. It has a valve on top of the trans that says "Quick Dump Valve". I does not make a difference which way that valve is the TPH still doesn't work.
Any help is appreciated.
If you have time to do it twice you had time to do it right the first time.
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
(INOP) 2020 CATERPILLAR 299D3 SKID STEER (A51242)
(INOP) 2020...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2019 Kenworth T680 Tandem Axle Road Tractor (A47384)
2019 Kenworth T680...
East Tri Axle Semi Dump Trailer (A50774)
East Tri Axle Semi...
