quick detach HD bucket setup
   / quick detach HD bucket setup #1
ewoss3
tulsa ok
kubota l3010hst/ford 601 workhorse
I've seen the quick detach HD bucket setup on the boomers and been wondering does Kubota have a similar setup that we can add to our current buckets. I would like to set up to change between forks and bucket quickly without trying to use the chain-on forks see picture for example. <A target="_blank" HREF=http://www.pbase.com/image/1395936>http://www.pbase.com/image/1395936</A>
   / quick detach HD bucket setup #2
Rob, Kubota does make a quick attach system for loaders. On my B21 it cost somewhere in the $250 range. You can also go with the Skid Steer attach type system.
MarkV
   / quick detach HD bucket setup #3
There are after market units available to cover nearly the whole line of Kubota's that are built today. You could start at your local dealer.
   / quick detach HD bucket setup #4
Rob
The <font color=orange>Kubota</font color=orange> Quick Attach system will work on loaders up to L3410. If all you have is <font color=orange>Kubota</font color=orange> attachments for your loader it is a good choice. The ATI system is heavy. By the time I added it to my 2910 I would loose about 300 lbs of load capacity. But if you want to rent or add Bobcat type attachments to your loader look at the ATI setup. Here is a<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=custom&Number=112292&page=&view=&sb=&o=&vc=1#Post112292> link </A>to a post on the <font color=orange>Kubota</font color=orange> system.
Thanks for the info the local dealer here did not have any useful info and my dealer is about an hour away so I haven't made it up there yet.
   / quick detach HD bucket setup #6
Ha! That's my tractor. I just clicked on the thread to see what the Kubota version looked like. Didn't expect to see my own.
I'm very pleased with how it works.
--Brad
Yep I saw your pictures and decided that I will have to put one on my wish list. you have a great looking tractor and house, keep up the good pictures and post
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
KUBOTA ZD1211 (A53084)
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
