quick attach
   / quick attach #1
crankin76
can any attachments that are able to attach to a skid steer able to mount on the kl451 if it has a quick attach plate
   / quick attach #2
Universal QA is 44 inches. So if the QA plate for the KL451 in 44 inches and the Skidsteer attachment is the standard 44 inches, you should be good.
I didn't want to throw out a general yes, because I remember reading somewhere, I think it was IT, saying that his factory QA was a little short. Also, I think Bobcat's older QA setup was propiratory.
   / quick attach #3
I don't know about the KL451 but as CrabJoe mentioned, the KL401 QA adapter is a few inches shorter than standard. However, it works with standard implements. I have used it on four different implements without any trouble. The "universal" skid steer attachment system does not require that every implement be exactly the same size, they just need to fit one of the pin holes to secure the implement.
2019 Caterpillar 299D2 High Flow XPS 95 HP Track Loader Skid Steer (A50322)
2019 Caterpillar...
10' Feed Bunk (A50515)
2014 International 4400 DuraStar Box Truck (A47384)
2014 International...
Miller Pro 5300 Silage Cart (A50774)
Miller Pro 5300...
Sullair RD3800 Compressed Air Dryer (A47384)
Sullair RD3800...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
