Quick Attach for L35 loader TL720
   / Quick Attach for L35 loader TL720 #1
cheekme
Virginia
L35
I want to convert my TL720 loader from a pin-on to a quick attach configuration. Then I will need to rework my standard Kubota bucket and W.R. Long forks from pin-on to coupler configuration. Any advice or recommendations for products would be appreciated. I'm tired of the messy change-overs between the bucket and forks.
   / Quick Attach for L35 loader TL720 #2
I have been looking to put a quick attach on my john deere 750. I was considering something like this
John Deere Pin on Loader to Skid Steer Quick Attach Adapter Compact Utilityfel'S | eBay
My only issue is that it weighs close to 120lbs. With a lift capacity of only 800 lbs for my machine it takes away too much of my loader capacity. Might work for you if you have a bigger machine. Nice thing about the skid steer quick attach (SSQA) is there are a lot of options.
Good luck.
Mike
   / Quick Attach for L35 loader TL720 #3
We offer the WR Long Pin-on to Universal Quick Attach Adapters for an easy transformation. Then, you'll just need to cut/torch off the pin-on bucket mount and weld on some universal plates.
Travis
2005 Morgan Corporation Flatbed Body (A50854)
2005 Morgan...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
71055 (A49346)
71055 (A49346)
2007 MACK CHN613 (A50854)
2007 MACK CHN613...
