Quick Attach Bracket To Wide?
   / Quick Attach Bracket To Wide? #1
gbell1577
John Deere 750
Good afternoon,
I just had a quick attach bracket made so I can hook up to my common skid steer implements. I was researching a few others out there and they are advertising the compact design of them, the width being short enough to preserve the lift capacity. One I read about was 2-1/8" wide from the from of the adapter plate to the back- mine is 9-3/4". I haven't noticed any difference, but would that be of concern to anyone? I didn't know if the additional 7-5/8" inches over that 2-1/8" would eat up to much lift capacity or not, or if I should have went with a more compact design. This isn't on a compact tractor and I have been running a tree grubber since this adapter can side shift over left or right and be mounted at any given time.
   / Quick Attach Bracket To Wide? #2
Not sure if it will matter to your application or not.
That said, think of the lever and fulcrum. That is basically what you are doing with your curl and dump cylinder from the pins. You need to see if you find specs for your loader. A frequent spec is either xxxx pounds at the pins or a more useful spec is xxxx pounds at 20” in front of the pins.
Now your almost 20” of latch mechanism cost you 1/2 of that distance For some uses that may not be an issue. For others, that distance may be critical.
Of course these concerns are much greater when the lift capacities are much lower. (IE 800lbs lift ability is a bigger issue than at 3000lbs)
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
2015 GMC Yukon XL Denali SUV (A50324)
2015 GMC Yukon XL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
