BRYBURTON
I haven't been able to start my tractor since it has warmed up.
Question 1) What is "ST" on the ignition switch? There are four positions beside the ignition switch "ST OFF ON START".
Question 2) I'm pretty certain that my glow plugs are not working. Do they need to be hot in order to start the engine when the air temp is 80 F?
Question 3) It seems like there is a sweet spot on the throttle when starting the tractor. Where do you position the throttle when starting your tractors? Do you keep it in one place, work it back and forth, other?
Thanks for any advice.
