Backhoe questions on 3 pt. hitch backhoe on TC35D
   / questions on 3 pt. hitch backhoe on TC35D #1
jlong
Bronze Member
West Virginia
NH TC35D
I have been hearing that there may be some issues with using a backhoe attachement using a 3 point hitch mount. I am using a Woods 750 backhoe on a NH TC35D tractor.
I use the BH once in a while to dig rocks and small stumps out of pasture so I don't hit them while mowing.
I was assured by the dealer that this was not a problem and that this is a common configuration with no consequences or concerns. The dealer also said that this did not affect the warranty of the tractor.
Appreciate any past experience/information.
J Long
   / questions on 3 pt. hitch backhoe on TC35D #2
I assume you are asking if you need a subframe? I have a woods 750 on my TC45D. No problems to date. The hoe was mounted on my JD970 off and on for 9 years with no problem. It has no subframe. I have used it long and hard but not abused it (lifting front tires off the ground, etc). At the risk of getting chewed out I do not think you need a subframe unless the machine has the backhoe on most of the time and is used for heavy digging regularly. I have seen tractors with 3pt backhoes that had cracked in half and heard about it on this site so I know it happens but I think if you are an occasional user and take it easy on your machine you should not have a problem.
JT
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
MILWAUKEE 52" HIGH CAPACITY MOBILE WORKBENCH (A51248)
MILWAUKEE 52" HIGH...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51248)
UNUSED TOPCAT...
(8) DRAWER METAL TOOLBOX (A51248)
(8) DRAWER METAL...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
NEW HOLLAND TN75SA TRACTOR (A51247)
NEW HOLLAND TN75SA...
