Questions: Loader/chains/hazzard switch
   / Questions: Loader/chains/hazzard switch #1
BlakesL
Good Morning,
The Kubota B8200 HST E that I'm looking at (730 hours, $3,000) has a small crack on the loader at the bottom of the right bracket. Is that a big deal?
Also, it has turf tires and I'm thinking that to move any snow I'll need chains, but there isn't much clearance under the fenders (13.6 - 16 tires), does anyone have experience with using chains on one of these and was clearance an issue?
Finally, the rear lights do not work and the hazzard switch is missing. Any thoughts on how easy or hard it might be too find the part and fix this problem?
Thank you!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
