Questions for anyone who has grown vegetables in plastic
   / Questions for anyone who has grown vegetables in plastic #1
jsconner1
Muncie, IN
AC 185
Hey everybody!
I have spent the last 3 years or so trying different things with growing vegetables in plastic to see what works and doesn't work. I have some ideas for next year, but thought I would put them out there to see if they did/didn't work for anyone else.
1. I learned that if you don't use a tiller on the soil (at least in the clay of Indiana) then you end up with lots of lumps and your plastic doesn't lay smooth. That being said I am looking to try raising the beds with a new plastic layer next year and I am wondering how wide of a swath I need to till to form the bed and lay the plastic. I.E. If I have 3' plastic (that ends up giving a 2' wide bed by the time I bury it on either side) would a 4' tiller give me enough loose dirt?
I imagine that a 3' tiller would not leave me enough margin, but I haven't tried it.
2. I'm looking for a tractor to run my water wheel transplanter. My AC 185 doesn't go slow enough. Throttled all the way down it is just a bit over 1 mile an hour. We mostly set hot peppers and I do 16-18" spacing. I have seen a lot of people say they have had success with either a MF 180 or 245. Unfortunately those are almost impossible to find where I am at. Has anyone tried it with a D17? There are plenty of those around and I have lots of experience with Allises. My dad had a 185, a C, and a D19.
I also have a line on a MF 175. I would assume it would be in the same speed range as a 180, but tractor data doesn't show any speed data for it. Anyone have any idea?
Ideally, I want something that will get down around 0.75 miles an hour, but anything under 1 mph should be workable.
Thanks for the help.
   / Questions for anyone who has grown vegetables in plastic #2
Lsconnner1
To plant vegs on plastic I would suggest that you disk/till ground flat and smooth with whatever size tiller you have. Next I would broadcast any fertilize that you would use. Then take a hipper disk to make about 2 ft wide rows. Run blade of hipper disk in last furrow thus making about 18" middle. This will throw all fertilize to top of row. The plastic layer machine has a bed former to make about 2 ft wide by 6" high bed/row. You will need
4 ft wide plastic. Also most plastic layer machines have a spool to put drip line/tape
Under plastic at the same time you lay plastic. Hope this helps. m
   / Questions for anyone who has grown vegetables in plastic #3
You growing commercially, or for personal use ?
Nolt's Supply in PA sells a lot of row stuff at great prices (I buy my greenhouse plastic there....he beats most places by 30-40%). He sells a nice raised bed, mulching, drip tape machine:
Home
Online presence is kinda clunky, you have to down load the catalog in PDF format, but his prices make it worth the effort.
Load Out (A47164)
Load Out (A47164)
2011 Land Rover Range Rover Sport AWD SUV (A48082)
2011 Land Rover...
10FT BUMPER PULL TRAILER (A48992)
10FT BUMPER PULL...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
45017 (A48082)
45017 (A48082)
