questions about valves leaking
   / questions about valves leaking #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
ok tractor heads- here goes. on my backhoe, a few of the valves seem to be leaking or because there is alot of dirt on the underside i can tell that two of the valves are wet..
now, i'm calling the valves the underside of the joystick levers that control up down side to side etc...
1) the valve leaking doesn't seem to be a bad leak, just moist dirt.. Is that problematic? Will that affect the power of the backhoe?
2) the main hose that comes from the sump- into the valve assembly also is leaking slightly yet moreso- - the question is, Will this affect the power of the bh?
3) Can a cylinder (rotating boom cylinder) that is leaking quite noticeably leaving a puddle after work - affect the Overall output power of the bh?
Guys, thanks for all the advice past, present and future..
db
   / questions about valves leaking #2
Small leaks should not effect the BH performance. The leaking cylinder could effect performance of that function.
thanks oldnslo:thumbsup:
   / questions about valves leaking #4
Why not install a 3000 psi hyd gage and check the relief pressure and see if it is close to factory specs.
If not, reset the pressure.
Wet spots and up to 10 CC per minute are acceptable according to Prince for their valves.
Internal leaks will cause you to lose power, and you can expect it to occur over time as seals harden and start breaking down.
A loss of power can be caused by worn valve spools, leaking seals, or tractor pump wear.
So a hyd gage is a good thing anyway you look at it. Just use it to monitor and troubleshoot the hyd system.
I just read a thread on that .. seems like the simple way to know whats going on. thanks for the confirmation and tips j_j.
db
   / questions about valves leaking #6
Just as importantly with the leaking cylinder it to keep a close eye on the hydraulic fluid level in the reservoir. If it is leaving a puddle on the ground, it is significant & you should plan on repacking the cylinder. There are several threads on repacking/redoing the seals on hydraulic cylinders. Kits are fairly reasonable considering the cost of hydraulic fluid & ground contamination cleanup if you get hit by OSHA or an environmentally conscious home owner.
   / questions about valves leaking #7
Drips are nothing, spraying is something else!
before i bring this in i am curious of what your experience can diagnosis the problem of the swing cylinder as being... here is a vid of it in action
   / questions about valves leaking #9
Shaft seal leaking.
ok got it
thank you
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
200722 (A51247)
200722 (A51247)
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
