SwingOak
- Joined
- Jan 31, 2011
- Messages
- 238
- Tractor
- '65 IH Cub Lo-Boy, '13 Kioti DK50SE HST, '20 Kioti RX7320
I recently bought a hammer knife mower for my Cub, it turns out it's a Mott FHC. It mows pretty well, even with dull, rusty knives:
It doesn't fit my lo-boy very well, I can't lift it off the ground very much without the PTO shaft hitting the fast hitch cross bar, and the PTO drive line angle is way too sharp. Exactly the reasons (as I've discovered) Mott made the LB model for the lo-boy.
In doing a little research, it looks like the only difference between the two models is the driveshaft and driveshaft tube length, and possibly the driveshaft mounting height. I think I can modify the mount so that I can convert the mower to work on either a standard Cub or a lo-boy. I would just need to make a new driveshaft, driveshaft tube, and add another mounting bracket. Shouldn't be too difficult, I think.
Can anyone with a Mott LB share the driveshaft tube length (between flanges) and driveshaft tube centerline height? Thanks!
