Questions about Iseki TS1910 transmission
   / Questions about Iseki TS1910 transmission #1
gkirby
I recently bought an Iseki TS1910 tractor. I have gone over it, repainted it, and replaced the idiot lights on the dash with gauges. The brakes are on a shaft in front of the rear axle. The seals behind the brake drums were leaking so I tried replacing them. The left side wasn't too much of a problem. Put two bolts into the threaded holes in the brake drum, tighten them, and the drum pushes out and off. The plate behind the brake drums where the seals are mounted in had the same two threaded holes. I put two bolts in the holes, tightened them and the whole assembly came out. I replaced the seal plus the noisy ball bearing and reassembled everything. When I tried the right side, the drum came off easily. I tried to remove the assembly holding the seal, bearing, etc. and it wouldn't come out. I spent the biggest part of a whole day trying to get this assembly out. The bolts finally stripped the threads out of the holes. I retapped for larger holes and stripped out at least 8 bolts. Then I noticed than when I tried to pull the assembly out, the pedal going to the differential lock was moving up and down. It seems that something having to do with the differential lock is keeping this assembly from coming out. I went ahead and replaced only the seal, but could not get the assembly out of the transmission block to get to the bearing and I couldn't get to the gasket which sealed this assembly when it was tightened. I don't think it is the seal leaking, I thing it is the gasket (and O-ring which slides on the assembly and helps seal the assembly.
I have a manual I bought for the tractor. It goes into great detail on rebuilding water pump, starter, alternator, injector pump. etc. It doesn't even mention how to get these gear/seal assemblies out of the holes so the bearings and seal can be changed. I need help from someone who has a knowledge of this tractor. Any help from anyone would be appreciated.
gkirby
   / Questions about Iseki TS1910 transmission #2
You have to open the housing via the top plate and remove dif. lock and main drive gear to get the assembly out I had to pull the gear shaft to the PTO gears
just a little to get the drive gear out there are snap rings on both
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
1267 (A50490)
1267 (A50490)
