Question to 551C owners
   / Question to 551C owners #1
Donegal_TDI
Bronze Member
Donegal, Ireland
SAME100.4 Kioti551C XUV855D
At the rear left top corner on the exterior of my cab there are 2 wires with a connector for a beacon.
My question is do any of you have a beacon fitted by a dealer and where internally was the switch fitted in the cab.
This might point me to where I can install a switch and pick up the connectors inside the cab rather than trace the wiring.
Someone might have access to a wiring diagram.
Thanks.
   / Question to 551C owners #2
Don't know. Mine (DK 45 Cab) has lamps mounted on top of the cab. The switch is on the upper console. If you plan on doing any kind of modification to the lighting or adding more, be sure the circuit can take the load.
The cab top comes off pretty easy for doing any work to the insides.
   / Question to 551C owners #3
Thanks.
I have a DK45 cab that has a connector. It also has pre drilled holes that are covered that appear to be there to mount a light. I am going to check to see if it isn't already pre wired to one of the light switches. Top lights are ok, I believe they are flood, but a spot light to point to a hay rake when I am raking at night would be nice.
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50324)
2004 Stage Line...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
