Question on timing on mowing plots
   / Question on timing on mowing plots #1
abatis
Bronze Member
Greetings, I finally have the right equipment (rotary cutter) to mow about 8 acres of grass and weeds for use this year as food plot and some pasture.Come spring it will be wet and messy for a while given the soil type. I never mowed the area down last fall and I am now wondering if there is anything wrong with mowing the surface grass/weeds stems down now while the snow is gone but the ground is still frozen? I am hoping this will make growth of existing grass for pasture easier as the property has been ignored for years. I also want to frost seed some legumes between now and the end of March. Thanks for any suggestions. Location is western Montana
   / Question on timing on mowing plots #2
If the ground is frozen and there is no chance of rutting it up you should be good to go.
   / Question on timing on mowing plots #3
If you can do it safely, burn it off.
Thanks for the replies. Ground was good to go yesterday and mowed about 8 acres with my new Landpride RC1860. Worked great on the Bobcat CT235. Thanks for the advice, now to get to the frost seeding.
SET OF (4) TIRES / WHEELS (A50460)
SET OF (4) TIRES /...
2015 Ford F-150 4x4 Pickup Truck (A48081)
2015 Ford F-150...
2023 Vivid EV Golf Cart (A48082)
2023 Vivid EV Golf...
2013 Massey Ferguson 9250 (A47164)
2013 Massey...
DOOSAN G90 PORTABLE DSL GENERATOR (A50460)
DOOSAN G90...
2014 Ford F-250 Pickup Truck, VIN # 1FT7W2B66EEA79923 (A48836)
2014 Ford F-250...
