"EquipmentJunkie, you lost me. What tethered plastic block? Doing this would pull the clutch disk away from the flywheel to prevent sticking? If it was stuck, wouldn't just pushing in the clutch break it free? "
If a clutch is rust frozen, sometimes it can be broken loose by popping the clutch...but sometimes the transmission has to be pulled and the clutch replaced.
If the tractor is going to set idle for an extended time (during the winter, for example), it's best to block the clutch pedal in the depressed position.
on my 790, there is a tab of metal (a stop, I think) welded to the floor board. I use a clamp or vice grip plier to hold the clutch pedal down.
