Question on suction hose
   / Question on suction hose #1
NCMau
NC
MF 202/Ford 8N
I have to replace the power steering suction hose. The suction and the pressure are both 1/2" hoses. I would like to use a 3/8" for a flexibility issue and leave the existing 1/2" pressure hose in place. I realize that normally the suction should be larger or at least the same size.
My question is, since the steering is a low volume system, can I get by with a 3/8" for suction?
I would prefer to use the 3/8", but it is not absolutely imperative.
   / Question on suction hose #2
it is not something i would recommend the mfg. already took into account the low flow and used the same size hoses. if it is flexibility try gates or flexdraulic hoses
Well I didn't really think that I was going to get away with this idea. Thanks for the tip, I'll look into these flex hoses.
   / Question on suction hose #4
A 1/2" suction hose is already smaller than normal. I would not mess with it. If your pump can't get enough fluid because the input hose is too small, you could be looking at some very expensive pump repairs.
   / Question on suction hose #5
Look into some manufacturers 1/2" hose that has thinner wall and more flexible. I think the spec is 100a7
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
