Snow Blade Question! on size
   / Question! on size #1
CaptainNoah
Miamitown, Ohio
John Deere 1026r
I have a new John Deere Series 1 diesel subcompact tractor. Question, what would be the biggest size rear blade I should attatch. I have been thinking about a 5' blade. Thanks for reading my post.:
   / Question! on size #2
I picked up an old 72" rear blade for mine. I had every intention of cutting it down to 60" before I used it for snow removal. It depends on your intended use, the size blade a scut can handle. I have a 48" box blade for dirt work, so I'll leave the 72" blade alone for snow removal. For dirt work however, I believe the 60" rear blade would be best. Check out these vids for one series rear blade action:
http://www.youtube.com/watch?v=8xrHDJOT_28&feature=youtube_gdata_player
http://www.youtube.com/watch?v=u-188_IMeUk&feature=youtube_gdata_player
   / Question! on size
Thank you for the reply. I enjoyed watching the videos. I hope to purchase one this week.
   / Question! on size #4
zI agree with a 5' for dirtwork and a light 6' for snow. I use a 5' for my 749 and it is a good fit.
   / Question! on size #5
If you intend to move any wet snow, or lots of soil, then you may want to have that blade set at 30 or 45 degrees (about the vertical pivot). Measure your rear track, from outside sidewall to outside sidewall. Take this measurement and divide by .866 for 30 degrees or divide by .707 for 45 degrees. This will tell you what size you need to cover your wheel tracks set at that angle.
eg: rear track = 47" set at angle = 45 deg
47/.707 = 66.5" So at least a 5.5 foot, more likelya 6 foot would do.
Depending on how much weight you are trying to move, and how much traction you have, you may want to go shorter. Or you may want to add rear chains or ballast (or both) and go longer. Your call.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
2009 Subaru Outback AWD SUV (A50324)
2009 Subaru...
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
