Question on model names
   / Question on model names #1
keenlanp
Dorr, MI
Branson 3015H, Yanmar YM 240D, YM 186D
Folks,
My understanding is that US models are named based on engine hp and whether they are 2 or 4 wheel drive and powershift or "normal" transmission. So my 240D is a 24 horse 4 wheel/front assist model with a normal gear tranny. So, what's up with the 135, 155, and 165? Tractor data.com list them all as even hp (13 for a 135, etc.) when the normal naming convention would indicate 13.5, etc.. So why the 5 on the end? On a somewhat related note, what is the 169? I think all of the US model powershifts end in a 6 or 7, so what does the 9 in the 169 indicate?
On a totally unrelated note, does anyone have the dimensions for a 135? It is one of the models without that info on tractor data.
Thanks as always for the education and have a great week.
   / Question on model names #2
You'll go crazy tying to figure that out.
   / Question on model names #3
There different powershift locations. I know the grey versions like 2010 and 2020 were I believe on the trans a d on the dash/steering column respectively. May e I ha ethat reversed. I'm sure the american models like 186 187 are similar I just don't remember. Pretty bad. I have a 186 sitting outside right now, but it's not running and I bought it this way and I have t hot around to it.
   / Question on model names #4
YM186 had the Powershift shift lever on top of the transmission (early) then on the left side of the dashboard (late). The same parts manual covers both of those. Then YM187, the subsequent similar model, was all dashboard shifter - I think. YM187 has a slightly larger chassis for more legroom, wider tires, its essentially an upgraded 186.
Yes I think the Japan-market models used 10 or 20 to indicate transmission or dash shifter location The 20's were subsequent to the 10's.
Also the US market models are named for engine naked dyno hp while the Japan-market models were named for the PTO output hp. YM240 = YM2000 etc. Those two have the same identical engine. Also YM186 (US) = YM1510 (japan). Same engine, same tractor. In both these sets of twins the US versions have some safety-feature differences, otherwise identical.
   / Question on model names #5
Folks,
You can see the 135 dimensions here.
  • Yanmar135_155_Vue_eclatee parts manual.pdf
   / Question on model names #6
For a starter the US YM models were YMXXX. The first 2 numbers were Engine HP ratings. I am not sure on what the 3rd digit represented
On the gray market (build for japan markets and then later imported ti US and other countries), are a YMXXXX. On these the 1st 2 numbers represents the PTO HP. The last 2 digits represents different features. 00 being a ‘base’ model and usually a 2 cylinder engine. 10 being a power-shift model with the gear selector on top of the tranny, and 20 being on the dash.
On both XXX and the XXXX a D at the end indicated 4x4 or front assist (if you will).
So to use mine as an example YM2002D, is a gray market, 20hp at the PTO, 3 cylinder engine (has a bit less of the classic Yanmar hammer), has a creeper range (have only used it to verify it works, a baby can crawl faster than 3rd gear) and 4x4
Hope that clarifies some of your questions.
   / Question on model names #7
And then, just when you think you have it figured out, there are the 3 digit gray market models like the YM177 and YM273 and then the YM1502 without wet brakes and the YMG2000 3 cylinder tractors that go and mess it all up. :laughing:
   / Question on model names #8
Aaron, have you issued a recent list of best-supported models based on parts you stock or can obtain? How about JD stuff?
   / Question on model names #9
I have been working on that list a little more this year just to add some specific model examples but I keep getting sidetracked. :) Not much has really changed though. Pretty much all of the YM stuff is still going pretty good. There are some very slow selling & very expensive to reproduce stuff that is hard to get right now like maybe the YM1300D/YM155D 4wd knuckle castings and some of the YM1510 4wd knuckle gears. Stuff like that. We've looked into getting some of those pieces reproduced but it is a very large investment that will just never pay off. We have reproduced a lot of stuff that we knew would never pay off just to keep the tractors going but, once you start to get quotes in the 5 digits, it gets harder to swallow :)
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2016 Ford Explorer...
2014 Freightliner M2 106 Medium Duty Truck with Tool Bed, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
