Question on Model 70 Loader....
   / Question on Model 70 Loader.... #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
Was looking at my loader today and noticed where both cylinders that lift the loader arms have some gap between the end mounts that slide onto the pin's, and the upright brackets of the loader frame. It looks like it's maybe 1/4" or so. Is this normal?? Or should I undo the cotter pins, slide the pin out, and maybe put a couple bushings on each side (to center it up) to take up the slack? It may not be an issue, but I thought it worth asking about. Btw, both sides have the gap on the same side (left) as you would view it from the drivers seat.
Here's the cylinder on the leftside (from the driver seat)
Here's the cylinder on the other side:
   / Question on Model 70 Loader.... #2
I have the same loader kebo, with the same gaps. Not a big concern as nearly all of the load is perpendicular to the pin. I wouldn't worry about it, just keep 'em greased.
   / Question on Model 70 Loader.... #3
That is normal...
Thanks guys, I didn't think it was a problem but wanted to ask. Will shoot them with the greasegun before I get back on it.
PAIR OF 5' PIN ON FOLD UP RAMPS (A54756)
PAIR OF 5' PIN ON...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2021 Chevrolet...
UNUSED LANDHONOR ABC-13-125A HYD BRUSH CUTTER (A54757)
UNUSED LANDHONOR...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55218)
2008 Ford F-250...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
